Material.inherit()
the Material class has the inherit() function, what - according to the documentation does exactly what I want to do: I want to create a inherit a new material during runtime without storing it in any Material Libraries XML etc.
Problem is, if I do this:
Material material = baseMaterial.inherit("my_fancy_material");
mesh.setMaterial(material.getName(), "*");
I get the error message:
Object::setMaterial(): can't find "my_fancy_material" material.
I do not find any way to set the Material based on the Material Class instead of it's name tho.. so.. how do I use the inherit() function properly?
Cheers,
Daniela
PS: I can not use the Object::getMaterialInherit() function, since my new material needs to have a different parent than the current assigned one.
Hello Daniela,
Make sure you have material library loaded with your fancy materials. After that you can do inherit stuff.
Have a good day! ;)
