steve.brodie Posted August 24, 2010 Posted August 24, 2010 We are experiencing jitter or camera shake when cameras are exported a long way from the origin (4km). A test video with the jitter present is attached. When the same camera path was exported at the origin the path was smooth. This problem did not occur on a job we did 18 months ago using an earlier engine version. Brodie Jitter Test.wmv
frustum Posted August 25, 2010 Posted August 25, 2010 We are experiencing jitter or camera shake when cameras are exported a long way from the origin (4km). A test video with the jitter present is attached. When the same camera path was exported at the origin the path was smooth. This problem did not occur on a job we did 18 months ago using an earlier engine version. Brodie Please create a small reproduction sample and we try to fix this issue before next update.
steve.brodie Posted August 25, 2010 Author Posted August 25, 2010 Please create a small reproduction sample and we try to fix this issue before next update. I have attached the camera path text that you can see the jittering in. You may need to have something close to the camera to see it shaking. If this is not enough info I may be able to put it in tropics demo? and put some geometry in close to the camera. Thanks Camera Paths.zip
danni.coy Posted August 26, 2010 Posted August 26, 2010 I came across some very interesting information in a game post mortem. It seems that adding a very large floating point number to a very small floating point number will loose accuracy in the very small number. Would it be possible in the max mesh/smesh plugin to internally convert all coordinates to doubles before doing any calculations then set the precision down right at the end. I am not so sure how to deal with the max script portions (camera export) other than reorganising the matrix calculations so that transformation matrices are multiplied rather than added. The example I have is [scale][Rotation][Translation]x[Translation][Rotation]x[Projection] becomes [scale][Rotation]x[Translation][Translation]x[Rotation]x[Projection] for a model view projection. I am not sure how much sense that makes.
frustum Posted August 26, 2010 Posted August 26, 2010 I have attached the camera path text that you can see the jittering in. You may need to have something close to the camera to see it shaking. If this is not enough info I may be able to put it in tropics demo? and put some geometry in close to the camera. Thanks Try this updated camera path script.
ulf.schroeter Posted August 27, 2010 Posted August 27, 2010 Try this updated camera path script. Hi Alex, unfortunately the updated camera path script you mentioned is not visible to other users. Short comment on original problem cause would also be very helpful. Thanks
frustum Posted August 27, 2010 Posted August 27, 2010 There was SDK build with inexact orthonormalize() function. This script should handle this bug correctly. camera.h.txt
steve.brodie Posted September 6, 2010 Author Posted September 6, 2010 Hi Alex Thanks for that. It seems to have reduced the problem but not removed it. Is there any way to increase the floating point accuracy. Steve
frustum Posted September 6, 2010 Posted September 6, 2010 Hi Alex Thanks for that. It seems to have reduced the problem but not removed it. Is there any way to increase the floating point accuracy. Steve I will try to add support of double types in Unigine Script on days.
ulf.schroeter Posted September 7, 2010 Posted September 7, 2010 I will try to add support of double types in Unigine Script on days. The jittering problem seems to be more general. There is a very good section 3.2.6 "The Jitter Bug: Dealing with Floating-Point Precision" (danni.coi referenced it) in the "Making it Large, Beautiful, Fast and Consistent: Lessons Learned Developing Just Cause 2" by Emil Persson in GPUPro. Even with with a not too lage game world coordinate system ranging from -16.384 -> 16.384 [m] they encountered numerous vertex/animation jittering problems and z-precision lost I think Alex already has included some precision-fixes in vertex shaders, but camera-relative per-instance matrix calculations (also known as camera-centric floating origin approach e.g. http://www.floatingorigin.com) are currently not implemented.
steve.brodie Posted September 28, 2010 Author Posted September 28, 2010 We are also getting jitter in objects animated on a spline. This objects motion is a train that starts and stops. The video shows the jitter when the train is stationary. Will these issues be fixed with double types? as I need to know for a current project otherwise will have to keep moving my geometry to the origin as i fly around. jitters.wmv
ulf.schroeter Posted October 27, 2010 Posted October 27, 2010 I will try to add support of double types in Unigine Script on days. Hi Alexander, it would be great if Property class would also support double parameter values (e.g. for attaching double-precision world coordinate values to objects) via something like void Property::setParameterDouble(int num,double value) double Property::getParameterDouble(int num) double Property::getParameterDoubleMin(int num) double Property::getParameterDoubleMax(int num)
frustum Posted October 28, 2010 Posted October 28, 2010 Hi Alexander, it would be great if Property class would also support double parameter values (e.g. for attaching double-precision world coordinate values to objects) via something like void Property::setParameterDouble(int num,double value) double Property::getParameterDouble(int num) double Property::getParameterDoubleMin(int num) double Property::getParameterDoubleMax(int num) Double properties and double types in xml parser is ready.
