jianghua.wei Posted September 29, 2014 Posted September 29, 2014 Dear support, I 'm trying to rotate a sprite in the screen, the rotation aix is perpendicular to screen.The center of the sprite is (x, y), the angle is 60 degree. 1. I tried to use setLayerTexCoord (int layer, vec4 texcoord) , define the new coordinate of (x,y,z,w), but it doesn't work. the code I used is: float a1 =a*cos(m)-b*sin(m); float b1 =b*cos(m)+a*sin(m); float c1 =c*cos(m)-d*sin(m); float d1 =d*cos(m)+c*sin(m); vec4 xx =vec4(a1,b1,c1,d1);//this is the new coordinate sprite.setLayerTransform(0,xx); 2. I tried something like sprite.setLayerTransform(0,::rotate(x,y,0.0f,n)); but it looklikes strange for the rotation result, is this work? how to define the right coordinate in this case? 3. I tried another method, failed... Image image =sprite.getImage (); image.rotate(60); sprite.setTexture(image); Best regards, Joshua
silent Posted September 30, 2014 Posted September 30, 2014 Hi Joshua, Have you checked samples/widgets/sprite_00 sample? There is a small example of sprites rotation. If you still have issues, please send us minimal test scene for reproduction. Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
