[SOLVED] Set parameters for callback function at XML
Class Widget has function to set callback:
WIDGET::setCallback (int callback, variable function, variable data_0,variable data_1, variable data_2, variable data_3)
This function can have up to 4 function parameters (data_0, data_1, data_2, data_3).
We can also set callback function name at ui-file
Source code (XML)
<callback type="clicked">Window::close_window</callback>
Can we set parameters for callback function at XML ?
Hi Dmitry,
Yes, you can easily set your custom parameters. For example:
<callback type="clicked" string="Hello">Window::close_window</callback>
void close_window(string FromXml) {
   log.message(FromXml);
All available parameters you can find here: https://developer.unigine.com/en/docs/1.0/code/gui/ui_widgets
Hi Dmitry,
For string it works.
I would like to pass int parameter through XML.
I tried to use variable parameter, but didn't get success.
What should I do ?
Ok, thank you, it works.
How to use variable parameter, I didn't understand from Docs. There isn't clear for me too.
Where is declared this variable: in xml or in UnigineScript ? How to use it ?
You can pass variable by it's name, like this:
//cpp
int variable = 100500;
void callback(int var) {
 log.message("var: %d",var);
//ui
<checkbox align="expand">
   <callback type="clicked" variable="variable">callback</callback>
   <text>CheckBox</text>
</checkbox>
Thank you very much, there are no questions.
