Cant install UE kit onto Win7 X64 due to an integrity check error
Hi Guys !
The title says all. I have downloaded it from the download section right know. There is a 2010-08-09 05:01:42 modified version stated, and what i downloaded is UnigineEvaluation-2010-06-28.exe so the two dates do not match ( IDK whether that counts ).
Is the installer incompatible with x64 ? Or what may be the problem ?
Thanks in advance.
might be your network problem, try not use a download manager.
All Unigine builds are supported x64 and x86 OS. May be the package is not loaded correct, try to download one more time.
I downloaded it again, nay two times, once with google chrome and the other time with mozilla neither worked. I dont use any DL manager. So i still have this error:
Dayyem ... :unsure:
edit: i managed to unpack the installer and tried to run main.exe, but it did not work, i guess the folder structure does not match the required and/or some entries are missing form registry. Could someone post me the folder structure of an installed UE kit ?
  • 2 weeks later...
Thank you very much, it wors now :) . Thread can be closed.
