CPU-intensive busy waiting (SpinLock, WaitLock)
running my program in valgrind (callgrind) I noticed a lot of CPU cycles are spent doing noting in spinlock and waitlock.
Looking at the code below this is no surprise, since the while loops are spinning full speed.
*******BEGIN ORIGINAL SOURCE****************
INLINE void SpinLock(volatile int *ptr,int old_value,int new_value) {
    #ifdef _CELLOS_LV2
        while(!AtomicCAS(ptr,old_value,new_value)) { sys_timer_usleep(1); }
    #else
        while(!AtomicCAS(ptr,old_value,new_value)) { }
    #endif
INLINE void WaitLock(volatile int *ptr,int value) {
    #ifdef _CELLOS_LV2
        while(!AtomicCAS(ptr,value,value)) { sys_timer_usleep(1); }
    #else
        while(!AtomicCAS(ptr,value,value)) { }
    #endif
*******END ORIGINAL SOURCE****************
Here is my proposal for an improved version which is also platform independent.
*******BEGIN IMPROVED SOURCE****************
        while(!AtomicCAS(ptr,old_value,new_value)) { Timer::usleep(1); }
        while(!AtomicCAS(ptr,value,value)) { Timer::usleep(1); }
*******END IMPROVED SOURCE****************
Spinlocks are much more efficient for short-term thread blocking as they avoid context switching (which would be forced by usleep ()). Even though your CPU load is higher, overall performance with this approach is better.
http://en.m.wikipedia.org/wiki/Spinlock
