[SOLVED] Infinite loop when i try create atlas image with less than 8 image
when i call Unigine::ImageAtlas.create(4096) function and set less than 8 images, then this function never end.
When set more than 7 images, then will end.
It in Unigine 2.0.
Thanks
Honya
I've tried to reproduce this behavior with simple usc script (just extract into <SDK>/data and run image_atlas.usc with USC Interpreter) and found that it is highly depends on incoming images sizes. Could you please provide us a reproduceable example with actual code and used images?
image_atlas.zip
silent: i check it and it work fine for variable count of images.
Thanks
Honya
