[SOLVED] User Widget
I creating my own widget and want to inherit it from base widget class like this :
class ProgressBarWidget : Widget
     ProgressBarWidget(Gui gui, string name): Widget(gui, name) { ....something....}
calling in other script
ProgressBarWidget pbar = new ProgressBarWidget();
gui.addChild(pbar.extern, GUI_ALIGN_CENTER);
and i have the following message
Is there some sintaxis error?
There is no easy way to inherit from base class. Could you please try to inherit from Unigine::Widgets. For example, using this code:
#include <core/systems/widgets/widget.h>
using Unigine::Widgets;
 int width = 150;
 ProgressBarWidget(int w) {
  __Widget__(w);
 ~ProgressBarWidget() {
  __Widget__();
Actually, you have a lot of options here:
1) Inherit from WidgetExternBase. That way you'll be able to create your custom widget from C++ side as well as from the script.
2) Don't use inheritance at all and use WidgetCanvas instead to draw custom graphics and event handling. So your custom widget will be a wrapper class over WidgetCanvas.
3) Inherit from Unigine::Widgets::Widget class in the script as it has support for both multi- and single window modes. That's the way silent had suggested you.
By the way, I've modified your code so it's working now. Please find it in the attachments.
Have a good weekend!
Empty.zip
Thank you very much!
it works great, I'll use 3'rd way.
I need to drow some custom texture inside widget with local (relatively to container coordinates), i think WidgetCanvas cant do this.
WidgetExternBase is ok but all GUI part of my application is already in scripts now, its bad to separate my code, and put widgets to c++ code.
I still have trouble adding my custom ProgressBarWidget widget to ObjectGui.
ObjectGui object_gui = add_editor(new ObjectGui(30.0f, 30.0f));
object_gui.setPosition(dvec3(0, 0, 10 + 15));
object_gui.setBillboard(1);
object_gui.setBackground(0);
object_gui.setMaterial("gui_base","*");
object_gui.setProperty("surface_base","*");
object_gui.setScreenSize(300, 300);
object_gui.setControlDistance(100000.0f);
Gui gui = object_gui.getGui();
ProgressBarWidget pbw = new ProgressBarWidget(10, gui);
pbw.stop();
WidgetVBox allContainer = new WidgetVBox(gui);
allContainer.addChild(pbw);
gui.addChild(allContainer, GUI_ALIGN_CENTER);
Empty.rar
I got this message
there is no trouble when i add widget:
addChild(pbw,ALIGN_CENTER);
That's because Unigine::Widgets::Widget script class is not inherited from C++ Widget class, it's a wrapper. That said, it won't work with gui.addChild method that way yet there're few ways to solve this.
You can either access its inner field
ProgressBarWidget pbw = new ProgressBarWidget(10,gui);
gui.addChild(pbw.widget, GUI_ALIGN_EXPAND);
or just use addChild method.
method gui.addChild(pbw.widget, GUI_ALIGN_EXPAND); works well
This is working test user widget
Empty.rar
Problem solved, thank you.
