Early access to OilRush for customers
We are pleased to provide early access to Oil Rush build/resources for our customers, we hope it will be helpful as a Unigine usage reference.
You can download the current build here: https://developer.un...rver/list/Games
Use "ung" utility to unpack resources (data/waterwar.ung).
Manual is in the "docs" folder.
Official website of the game: http://oilrush-game.com/
Disclaimer: Please take into the account that this is a pre-release version of the game, it's incomplete and contains some bugs. The build is for internal use only, any redistribution is prohibited.
I wanted to try the game, but after download, the file seems to be damaged :) , it's impossible to extract zip :) . It's late, i try again tomorow ;)
FYI, I also get a corrupt .zip file when trying to extract it. Very excited to try it out.
I have managed to succesfully extract the archive here... I am using ark (probably unzip) on Linux.
ooops, I'll check it in a couple of hours.
Use .bat / .sh launchers inside the archive to run the game.
Content is located at data/waterwar.zip
  • 3 months later...
  • 3 months later...
  • 1 month later...
Updated to 0.80: https://developer.un...rver/list/Games
Changes from 0.74:
2011-09-16 Oil Rush team <oilrush@unigine.com>
Version 0.8
* Massive performance boost (no slowdown even by huge battles)
* Improved network synchronization
* Blocked pause/unpause keys if some window is opened
* Increased AI speed
* Fixed a bug with cannon jerking by applying "Barricade" skill
* Added a scrollbar for the video modes list
* Custom resolution is working properly now
* Multiple fixes in DEB packages for Ubuntu/Debian
* Added RPM packages for Linux (64-bit only for now)
* Steam integration is in progress
2011-09-02 Oil Rush team <oilrush@unigine.com>
Version 0.75
* Fixed Qt-based launcher problem on Linux
* Fixed issues with Mac OS X build: visual artifacts are gone and forgotten (version 10.7+ is required)
* Added ability to play with a single-button mouse
* Improved performance
* Improved GUI for special skills
* New minimap markers
* Even more sounds to play with
* Fixed server re-election in the multiplayer
* Memory consumption has been reduced
* Increased level loading speed
* Fixed a lot of minor bugs
* Added .deb packages for Debian and Ubuntu Linux
  • 4 weeks later...
Updated to 0.81:
* Added Steam support (lobby, matchmaking, game sessions, achievements). The game will be available on Steam for all users only after the official publishing.
* Added 3 new music tracks
* Fixed "Follow the fleet" feature (activated by pressing "F" after issuing an order)
* Increased targeting module speed
* Fixed a bug with mirage objects inside the fog of war
* Improved fragments and shatters left when units/towers are destroyed
* Fixed unit flickering on the minimap
  • 4 weeks later...
Updated to 0.82:
Maps:
* Added "Tutorial 3" mission with cut-scenes. Learn how to divide units by type and conquer your enemy!
* Added "Sabotage" map (1 vs 1)
* Added "Sunset" map (1 vs 1, a limited set of units, Zeppelin in action)
* Added "Circle" map (1 vs 1, an experimental labyrinth design)
Gameplay:
* Added "Napalm" skill (splashes of burning oil damage units and towers)
* Added "Repair ship" skill (a ship repairs units around it)
* Added "Mine field" skill (both ally and enemy units get damage when hitting mines)
Code:
* Mac OS X build now supports multiplayer
* Implemented Steam invitations support
* Improved aircraft movement
* Reduced "HeapChunk"-induced crashes
* Fixed several GUI bugs
* AI level is set to "Normal" by default in the "Quick Game" mode
* Fixed a bunch of minor bugs
Visuals:
* Optimized Barracuda and Mantaray models
* Added canyon environment
* Added a Zeppelin unit
* Fixed Seagull units
* Added the fade effect in the main menu
* Added Unigine logo on the start-up
* Improved units destruction
Music:
* Added a new battle music track
* Soundtrack is now available in high quality as a pre-order bonus
We need RTS mod for engine , will you share its source code ?
IT will take long time to make all RTS things like A* and other implementations...
Oil Rush game sources (UnigineScript) can be found here: https://developer.unigine.com/fileserver/list/Games
There is a built-in pathfinding module in the engine, it is available even for binary licensees: https://developer.unigine.com/en/docs/1.0/code/scripting/library/pathfinding/
