UNIGINE 2.0 Beta: Editor Usability and Performance, Overall Stabilization
Main Changes
UNIGINE 2 has successfully reached the beta stage.
  • Usability improvements for UnigineEditor.
  • Performance optimization for complex scenes.
  • Oculus Rift DK2 support.
  • Extended C++ and C# APIs.
  • Added more usage examples and tutorials.
  • Overall stabilization.
Performance Optimizations
The diagram below demonstrates UnigineEditor performance boost from UNIGINE 1 to UNIGINE 2 in everyday operations with objects (selection, movement, rotation, undo/redo) on complex scenes. The amazing x120-x5000 speedup has been achieved for test scenes consisting of thousands of objects (3375-9261 static meshes).
The speed of other actions in the editor has been also improved, so now editing performance is on par with runtime capabilities of handling very complex scenes.
Scene Navigation Usability
  • Added the ViewCube providing the following functionality:
    • Displaying of the current camera position.
    • Quick switch of camera positions based on axes.
    • Quick switch between orthogonal and perspective projections.
  • The mouse cursor smartly sticks to the object while moving.
  • Added support for fractional values to camera speeds.
  • The moving speed in the track (crab) mode now depends on the distance from the camera to object.
  • Added camera tilts to the right and left (right and left arrow keys by default).
  • Fixed focusing on objects with multiple selected surfaces.
  • The flag indicating if the editor camera position has been saved will be written to the .world file.
  • Camera rotations are now based on quaternions that solves the gimbal lock problem.
Objects Selection
  • Added a Rectangle select hotkey (Ctrl + Left Click for the UNIGINE 1 preset).
  • Selected surfaces can be deselected by clicking them while holding Ctrl.
  • Fixed material detecting when clicking the object.
  • Added a flashing selection: a wireframe of the object will be shown on the selection and then will gradually fade (if Helpers -> Object wireframe option is disabled).
File Dialog
  • Added support for Home and End hot keys.
  • Added a dynamic update of the files.
  • Directories specified in the -extern_path command line option will be shown in the Bookmarks field.
  • File names are limited to 100 symbols.
  • Operations with files now work in the following way: a single click after 0.3 seconds enables renaming; double-click opens / saves the file.
  • Fixed engine crash when clicking a bookmark addressing to the nonexistent folder.
  • Fixed repeated opening of the dialog window when saving world via Ctrl+N.
  • Fixed scrolling when the mouse cursor is out of the file dialog area: it won't influence the camera.
  • Preview improvements:
    • Added info on meshes vertices, triangles and surfaces in the Preview section.
    • Previews are available for nodes that are less than 5MB, for meshes that are less than 50MB, for textures each side of which is less than 16384 pixels.
    • Fixed preview display after file renaming.
    • Added previews for all supported texture formats.
    • Added previews for .node files.
Other Editor Improvements
  • Added cylinder and capsule mesh primitives to the Create -> Primitive section of the main menu.
  • Fixed camera locking for all viewports.
  • Added a Screenshot button to viewports for fast screenshots.
  • Added a resolution selector to viewports (fixed resolution or fixed aspect ratio).
  • Added a Target node field to the Persecutor tab of the PlayerPersecutor node that allows you to specify the players target from the editor.
  • Disabled surfaces and nodes are now displayed in gray.
  • After removing the materials library from the list all its materials in the scene will be removed.
  • Removed the Hide panel option.
  • Added a Decal Grabber plugin that serves for optimization of content located at the large terrain distances. It replaces distant objects with a deferred orthographic decal thereby baking all of them into a texture. A plugin is opened in the Decals tab of ObjectTerrain in the Nodes window.
  • Nodes hierarchy will be saved after grouping.
  • Fixed support of double-precision floating values in the node Position field.
  • Fixed undo / redo operations for:
    • Mesh Combiner plugin.
    • Randomizer plugin.
    • ObjectMeshCluster and WorldCluster (CollectCreateExpand options).
    • ObjectBillboards (correct saving of the parameters).
    • NodeReference.
    • Material and property systems.
    • Sound, physics and renderer systems.
    • Position, rotation and scale widgets.
    • Texture arrays of a terrain.
  • Added .plugin files for editor plugins containing metadata.
  • Fixed editor reloading with the closed Plugins window.
  • Fixed editor panels overlapping when combining into groups.
  • Fixed manipulators calculations when editor camera parameters are changed manually via the world script.
  • Fixed bugs in the Node Export plugin.
  • Added grabbing of spot and omni lights to Terrain Grabber.
  • Fixed import of the terrain masks from RGB and RGBA files.
  • Terrain brushes:
    • Fixed crash when choosing 2D array, cube and 3D textures as sprites for brushes.
    • Fixed crash when using brushes on a non-square terrain.
    • Fixed saving of changes made by a brush when the mouse hold has been released beyond the terrain.
    • Fixed saving of changes made by a brush after quitting the engine without saving the world.
  • Added the Helpers panel providing:
    • Quick access to frequently used helpers.
    • Enabling visualization of nodes icons and gizmos.
    • Enabling visualization of shapes, joints and contacts.
Other Tools
  • Added a missed time value for 3ds Max export plugin.
  • Added an alphabetical sorting of surfaces and animations for 3ds Max and Maya export plugins.
  • Fixed FBX files loading in ResourceEditor.
  • Added a basic support for PLY ASCII format (it is principally designed to store three-dimensional data from 3D scanners) into ResourceEditor.
Renderer
Please note that a lot of rendering improvements (PBR, new shadows, etc.) are in the R&D stage right now, so it will be integrated into the SDK only after further stabilization.
  • Added support for Oculus Rift DK2 virtual reality headset.
  • Added a sample for a mesh_shadow_base material: materials / shadow_00.
  • Added a sample which demonstrates conversion into the world coordinates from orthographic projection mode: shaders / post_coordinate_01.
  • All "projection" material parameters in the .mat files must be renamed "perspective". This parameter has same fields and should be used only for perspective projection mode. For orthographic projections the "orthographic" keyword should be used.
  • Fixed fade distances calculations for child asymmetrical LODs.
  • Resulting LOD mesh of ObjectMeshCluster is now work correctly with the rendering Distance scale parameter.
  • Fixed minimum and maximum expanding values for wall configurations.
  • Deferred, orthographic and mesh decals are now displayed correctly in the orthographic projection mode.
  • Fixed morph targets weight calculations during batch-skinning.
  • Fixed changing of cluster and clutter virtual camera offset parameters that caused rendering artifacts with random switching of texture coordinates.
  • Fixed the Offset parameter of noise particles and physicals. Now it is possible to create huge scaling factors for noise fields.
  • Added setNumTexCoords0() and setNumTexCoords1() functions for static and skinned objects, which allow you to specify the custom number of texture coordinates (the corresponding getter functions are getNumTexCoords0() and getNumTexCoords1()).
  • Added support for internal resolutions like 4K in small windows for the AppGrabber plugin.
Introducing AppBorder Plugin
The AppBorder plugin is used to hide the SSAO / SSDO shading artifacts at the screen edges. The functions of the plugin are stored in the engine.border class.
The plugin is launched on the application startup by adding -extern_plugin AppBorder to the command line.
  • Added an isPermanentlyFocused() method to the InterfaceWindow class. It returns a value indicating if the window is in a permanent focus, meaning that it remains in focus even when its children window is in focus.
  • Added a getVisiblePositionX / Y() function to the engine.interface class. It checks if the window of the given width is visible on a screen with the specified border at the given coordinate. If the window is visible, its position will remain the same. Otherwise, it will be updated in order to make the window visible (taking into account the size of the vertical border).
  • The getCenterPositionX / Y() function of the engine.interface class would not return a value in the following cases: if the parent flag of the interface window is set to 0; if the window is hidden; if the window is not in focus; if the window is not an instance of the WidgetWindow class.
  • Added a setBorder() function to WidgetGroupBox interfaces. It sets a flag indicating if the one-pixel border is rendered around the widget content (in a shape of a box).
  • Added a new <image> tag allowing you to insert the image.
  • Added dx and dy arguments to the <xy> tag.
  • Added a new widgets / splash_04 sample.
  • Added addLineIndex() and addPolygonIndex() functions to WidgetCanvas interfaces. They add an index for the point of the line segment / polygon to the canvas widget. The corresponding sample is widgets / canvas_03.
  • Added a setItemSelectable function to WidgetMenuBox interfaces. It sets a value indicating if a given item can be selected (i.e. the item is highlighted when you point to it). The corresponding checking function is getItemSelectable().
  • Added an ability to use other widgets as menu items to the WidgetMenuBox class.
  • MenuBox will be rendered as external window if the Interface plugin is loaded. It also will follow the main window while window movements.
  • MenuBox will be always visible on screen borders.
  • Added trilinear filtering of GUI textures with mipmaps instead of bilinear (DDS format only).
  • Added support for all font parameters including spacing, offsets, rich and wrap options for the font <text> tag.
  • Added setMinExpand / setMaxExpand() functions to WidgetSlider and WidgetSpinBox interfaces. They set the minimum / maximum value, up to which the lower/ upper limit of the range of the slider / spinbox values can be expanded. The corresponding getter functions are getMinExpand / getMaxExpand().
C# and C++ API UnigineScript
  • Added a new Json class used to parse and create JSON formatted strings.
  • Restored a getNormal() function of the ObjectMeshStatic / Skinned / Dynamic classes.
  • Added a removeFast() container function (for vectors only). It deletes the specified element and puts the last array element instead of the specified element. Thereby the array length is reduced by one.
  • Added a copy() function to the Xml class. It copies all data (including the hierarchy) from the source class to the current one.
  • Added a set_hidden() file system function (for Windows). It sets the given file or directory as hidden. The corresponding checking function is is_hidden().
  • Added a getQueue() function to the Async class. It returns the number of queued asynchronous threads.
  • Added getFileSize() and getSize() functions to the Dir class. They return the size of file or directory correspondingly.
  • Added a setDistance() function to the WorldExpression class. It sets the distance starting with which the expression is not executed. The corresponding getter function is getDistance().
  • Fixed parsing of complex preprocessor expressions like "#if a > 0 || b > 2".
  • Fixed crashes on the stack overflow.
Engine
  • Added a setData() function to all editor, game, physics, render and sound modules. It updates user data associated with the class. This string is written directly into a *.world file.
  • Fixed collisions with objects for clusters and clutters.
  • Added a force flag to all stateSettings() and saveWorld() functions of render, physics and sound modules. It forces the saving of all parameters.
  • Added a force flag to saveWorld()saveState() and restoreState() functions of the material and property interfaces.
  • Added replaceMaterial() / replaceProperty() functions to the material and property interfaces. They replace the specified material / property with the new one.
  • Added a setEnabled() function to editor interfaces. It sets a value of the Enabled parameter that controls all internal additional engine processing (for example, reloading of textures when their recording time is changed and so on). For example, you can set the Enabled parameter to 0 when using Syncker in order to increase engine performance (as Syncker operates inside the editor environment and can reduce engine performance).
  • Added setForceEnabled()setDeflectorEnabled() and setNoiseEnabled() functions to particles. They enable / disable the particle system. The corresponding checking functions are: getForceEnabled()getDeflectorEnabled() and getNoiseEnabled().
  • Added removeVertex() and removeIndices() functions to the ObjectDynamic and ObjectMeshDynamic interfaces. They remove the specified number of vertices / indices starting with a given vertex / index. The removeVertex() function can optionally fix the index buffer after removal of vertices.
  • Added a setSurfaceName() function to ObjectDynamic and ObjectMeshDynamic interfaces. It sets a new name for the specified surface if it was added via addSurface().
  • setViewDirection() function of player interfaces renamed setView() and moved to the Player base class.
  • Increased precision of world transformation matrices inside the .world files.
  • Added an objects / skinned_07 sample showing usage of multiple morph targets.
  • Fixed keyboard autorepeat under Linux and Mac OS X.
  • Now is possible to use archives without password protection at the same time with using archives with a password protection.
  • Fixed saving of texture arrays for DDS containers.
P.S.: UNIGINE 2.0 stable release is virtually there!
Download Links
All files can be found in "Downloads" section of the portal: https://developer.unigine.com/downloads
Known Issues:
  1. [Fixed] Project Generator may not generate project if Project Path field is not containg spaces under Windows. Binary and Source SDK are affected. Example of the correct path: new_project_1.png
  2. [Fixed] SDK Browser (browser_x86.exe) can generate 0xc000007b exception on start under Windows OS.
  3. Possible crash after Clicking "copy" button in Materials menu.
  4. Missed UNIGINE_DECLARE_USE_MEMORY after Ptr::destroy method in UniginePtr.h file located in <SDK>/include folder. Can cause engine crash on memory deallocations.
    • solution: manually add UNIGINE_DECLARE_USE_MEMORY line in the UniginePtr.h:122 or use this patched file: UniginePtr.zip.
UPD: SDKs were reuploaded 12:00 CET time (2015-02-27). Fixed issues #1,2.
Thanks for the update,
Very interesting the article Port Angeles Workflow, just some questions about CityEngine?
  • What CityEngine version do you use? Basic or Advanced?
  • How do you export CityEngine assets to Unigine? FBX?
ivan.cuevas
I believe we used Advanced version.
We only exported roads meshes and placeholders for buildings positions into *.obj format (for City Import plugin). Obj can be easily converted to *.mesh via meshimport or ResourceEditor.
great improvement! thanks again.
But I'm wondering when can we see this PBR rendering?
Thank you! Oculus DK2 support!!
the demos look really amazing  B)
Was making a new plugin in Unigine 2 beta when I got error that MakeExternFunction, ExternClass identifiers 'are not found'. I've compiled against beta .h and .lib files. Also included UnigineEngine.h instead of Unigine.h. Any ideas?
Hi Santosh!
You need to include UnigineInterface.h header file.
Hello!
I cannot find the Raknet plugin in the Unigine 2 Beta Game SDK anymore.
Will it be removed from future Unigine versions?
Yes, RakNet plugin has been obsolete for a while and it was dropped in UNIGINE 2.
Hi chaps
Nice to see the beta version!!!
I'm migrated from the alpha to the beta version. So far so good, but when I call the editor from CLI I get the following error message:
I have to say, that I'm loading two own plugins.
Hope you can help.
Thanks,
Renato
Ahh I see!
You changed the arguments of the init function from string the PluginMeta. Where can I set the title and the name of the meta data?
Cheers,
Renato
Yes, each plugin must have {plugin_name}.plugin file, like this:
<plugin name="internal_name" version="1.0">
    <text>Title</text>
    <description>Description</description>
    <source>source.cpp</source>
</plugin>
This file will represented in PluginMeta class:
class PluginMeta {
    string name;
    string version;
    string title;
    string description;
    string source;
Thank you, thats no problem for us. I can work with the original c++ raknet library as well.
Always a nasty question: When can we expect the next SDK?  :rolleyes:
(cant wait to see the PBR!)
Cheers
Werner
The team is working hard on pushing it out in 1.5-2 weeks.
It will introduce a major workflow improvement (new SDk browser).
wow. cant wait. sounds exciting.
Thx for sharing the info.
cheers
werner
