v.chizhkov Posted March 13, 2015 Posted March 13, 2015 1. Launching Unigine Game SDK 2. Launching Cool SFX librfry 3. Choose: fire1 4. Launching the editor from console 5. Launch the node panel for editing the node 6. Delete everything except nodes: fire and fire_low1 7. Editing fire_low1: - deleting force - label Dymanic: Emitter=Point Sequens=50 Limit=10 Size=0,0,0 Direction=10,0,0 spread=0,0,0 Gravity=0,0,0 Velocity=3,0.8 Life time 0.3,0.1 Radius=0.3,0.02 Growth=0.1,0.1 - label Params : Type=Length Every check-box except 'Emitter enabled' and 'Emitter based' switch off Spawn rate=30 Restitution=0 - label Surfaces: Every check-box except 'Enabled' switch off - As a result we get something like a fire from the nozzle of the space rocket with the emitter point. Save changes 8. Bring the camera closer. As we see it's OK(see the screen shot in the point of creation) 9. Change the first coordinate in position from zero up to 10000000 10. Make the camera coordinate change too(Tools/Camera) up to 10000000 11. Let's try to move the object(moving fire on the screen). But we see that the fire visualisation was broken. The same is for bounding box and coordinate system (last was distorted) (see screen shot on a large distance from point of creation) So the fire is hardly ever seen or it is seen only in some positions. Perversions(Collisions) are changing depending on the distance (situation is coming worse in case of larger distance from the point of creation(ObjectParticles::world_offset)) In my opinion, this problem is non-exotic. The situation is quite usual. When we are trying to create a rocket with fire-on and moving it around the Earth on large distance(thousands km(millions m)) the fire starts "rotating" around the rocket. The problem is seemed to be connected with the lack of accuracy. When we are transforming nodes dmat4 is using double . But further the emitter's transformation cats double to float (ex. ObjectParticles::update_transform(): particles->setEmitterTransform(mat4(transform));
silent Posted March 16, 2015 Posted March 16, 2015 Hi Vitaly! First of all, we don't recommend to use Game SDK with float precision support for such large distance to objects. I've made a screenshot that shows difference between float and double precision builds (with regular ObjectMeshStatic). You can see that on left side of this picture object bounds are deformed (Game SDK), but on the right side everything is OK (Sim SDK): Switching to double precision will fix manipulators and objects bounds issues. If I understand you correctly you want to get a close-up view of the rocket engine and rocket itselft can be at the very distant point (for example, 10.000.000)? I've tried to reproduce it with double precision build and it seems everything is working fine after saving world and reloading it: Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
v.chizhkov Posted March 16, 2015 Author Posted March 16, 2015 I've used Unigine Game SDK only to show the mistake in your code. As for me, I use your SDK with the keys, that provide the highest accuracy (USE_DOUBLE, UNIGINE_DOUBLE) The problem is described below. I create the rocket model and it's fire. I move them on the long distance and as I can see: the fire is presented as a set of chaotic small particles that are appearing not from the nozzle of the rocket, as it was at the moment of creation, but around the rocket, in different places. Besides, they are situated on long distances from it. As we can see in the code of method void ObjectParticles::update_transform() the current position of the rocket is saved in world_offset and as for placing the fire (Particles), you subtract this offset, as the result the coordinate system of fire is moved to zero. This happens only at the moment of the fire creation(by the condition: particles->getNumParticles() == 0). If the fire with the rocket now are moved on the long distance, the fire position will be the result of subtraction "current rocket position" - "default rocket position" (default position is saved to the world_offset). The rocket position and the world_offset are double accuracy, but the local coordinate system of the fire is presented by float(Use_DOUBLE is used, as I've already mentioned). The fire particles are created in the local float accuracy system, which is non-zero value (it is far away from it). So after moving fire particles to the rocket coordinate system by adding world_offset, the particles are not involved into the nozzle's area, they are created far away from it. But If we delete the fire at this very moment and create it once again, the last position will be saved to the world_offset and everything will be OK, because the local coordinate system is now placed in zero. This is the result of reloading the world, as you said. For example: void ObjectParticles::update_transform() this is unigine's code: // emitter offset if(particles->getNumParticles() == 0) { Vec3 old_world_offset = world_offset; if(particles->isEmitterShift() == 0) world_offset = getWorldTransform().getColumn3(3); else if(particles->isEmitterEnabled() == 0) world_offset = getWorldTransform().getColumn3(3); But if we replace it by: // emitter offset if(particles->getNumParticles() == 0 || particles->getEmitterType()==Particles::EMITTER_POINT) { //!!! Vec3 old_world_offset = world_offset; if(particles->isEmitterShift() == 0) world_offset = getWorldTransform().getColumn3(3); else if(particles->isEmitterEnabled() == 0) world_offset = getWorldTransform().getColumn3(3); else if(particles->getEmitterType()==Particles::EMITTER_POINT) world_offset = getWorldTransform().getColumn3(3); //!!! After every update of the rocket translation, the last position of the rocket will be saved to the world_offset (now it is made once only at the beginning). And the problem is fixed. But I'm not so sure about using this part of code. May be it might spoil something else.
unclebob Posted March 17, 2015 Posted March 17, 2015 Hello, Vitaly! I've successfully reproduced that glitch and will report to our dev team, no ETA though. Thanks a lot for detailed instructions and for fix suggestions! Update: that cast from to mat4 is actually safe because we've translated emitter by the world_offset before casting.
binstream Posted July 8, 2015 Posted July 8, 2015 Solved, the bugfix will be available in the next SDK update.
