rpl89 Posted April 7, 2015 Posted April 7, 2015 Hi all So I'm a little confused. I am trying to run my Unigine world in "Direct3D11" (method: Hitting Esc, changing the API to "Direct3D11", Hitting "Apply" and then rebooting.) However, once restarted the application reopens in "OpenGL" - Whats confusing me is that I have the exact copy of the Unigine world on a different machine (which has the same specs) and all is OK. Also, the system which in unable to open the "Direct3D11" also has a worse frame rate than the other machine.... Any ideas? Thanks guys
silent Posted April 7, 2015 Posted April 7, 2015 Hi, Please, check your launchers and engine config. Probably you are passing the -video_app opengl parameter on engine start-up. Also, the system which in unable to open the "Direct3D11" also has a worse frame rate than the other machine.... Any ideas? It can be related to the GPU driver. OpenGL under windows in most cases working slower than DirectX 11. Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
