[SOLVED] Could somebody help me to convert this shader from Shadertoy into UNIGINE shader?
At work, I was asked to import a OpenGL shader written in GLSL from https://www.shadertoy.com/view/XslGRr into UNIGINE, and I have to add it as "post effect". It's whole bunch cloud with the sky and some lighting. I have been looking for ways to modify the original code, although it did compile, it only shows black screen. Could somebody with shader experience check out my the code that I have modified, or make it work just like the effect shown on shadertoy website in UNIGINE.
The code of my world script, material, vertex and fragment are listed bellow.
Thank you guys!
original code from shadertoy:
// Created by inigo quilez - iq/2013
// License Creative Commons Attribution-NonCommercial-ShareAlike 3.0 Unported License.
// Volumetric clouds. It performs level of detail (LOD) for faster rendering and antialiasing
float noise( in vec3 x )
    vec3 p = floor(x);
    vec3 f = fract(x);
f = f*f*(3.0-2.0*f);
vec2 uv = (p.xy+vec2(37.0,17.0)*p.z) + f.xy;
vec2 rg = texture2D( iChannel0, (uv+ 0.5)/256.0, -100.0 ).yx;
return -1.0+2.0*mix( rg.x, rg.y, f.z );
float map5( in vec3 p )
vec3 q = p - vec3(0.0,0.1,1.0)*iGlobalTime;
float f;
    f  = 0.50000*noise( q ); q = q*2.02;
    f += 0.25000*noise( q ); q = q*2.03;
    f += 0.12500*noise( q ); q = q*2.01;
    f += 0.06250*noise( q ); q = q*2.02;
    f += 0.03125*noise( q );
return clamp( 1.5 - p.y - 2.0 + 1.75*f, 0.0, 1.0 );
float map4( in vec3 p )
float f;
float map3( in vec3 p )
float f;
float map2( in vec3 p )
float f;
    f += 0.25000*noise( q );;
vec3 sundir = normalize( vec3(-1.0,0.0,-1.0) );
vec4 integrate( in vec4 sum, in float dif, in float den, in vec3 bgcol, in float t )
    // lighting
    vec3 lin = vec3(0.65,0.68,0.7)*1.3 + 0.5*vec3(0.7, 0.5, 0.3)*dif;
    vec4 col = vec4( mix( 1.15*vec3(1.0,0.95,0.8), vec3(0.65), den ), den );
    col.xyz *= lin;
    col.xyz = mix( col.xyz, bgcol, 1.0-exp(-0.003*t*t) );
    // front to back blending
    col.a *= 0.4;
    col.rgb *= col.a;
    return sum + col*(1.0-sum.a);
#define MARCH(STEPS,MAPLOD) for(int i=0; i<STEPS; i++) { vec3  pos = ro + t*rd; if( pos.y<-3.0 || pos.y>2.0 || sum.a > 0.99 ) break; float den = MAPLOD( pos ); if( den>0.01 ) { float dif =  clamp((den - MAPLOD(pos+0.3*sundir))/0.6, 0.0, 1.0 ); sum = integrate( sum, dif, den, bgcol, t ); } t += max(0.1,0.02*t); }
vec4 raymarch( in vec3 ro, in vec3 rd, in vec3 bgcol )
vec4 sum = vec4(0.0);
float t = 0.0;
    MARCH(30,map5);
    MARCH(30,map4);
    MARCH(30,map3);
    MARCH(30,map2);
    return clamp( sum, 0.0, 1.0 );
mat3 setCamera( in vec3 ro, in vec3 ta, float cr )
vec3 cw = normalize(ta-ro);
vec3 cp = vec3(sin(cr), cos(cr),0.0);
vec3 cu = normalize( cross(cw,cp) );
vec3 cv = normalize( cross(cu,cw) );
    return mat3( cu, cv, cw );
vec4 render( in vec3 ro, in vec3 rd )
    // background sky
float sun = clamp( dot(sundir,rd), 0.0, 1.0 );
vec3 col = vec3(0.6,0.71,0.75) - rd.y*0.2*vec3(1.0,0.5,1.0) + 0.15*0.5;
col += 0.2*vec3(1.0,.6,0.1)*pow( sun, 8.0 );
    // clouds
    vec4 res = raymarch( ro, rd, col );
    col = col*(1.0-res.w) + res.xyz;
    // sun glare
col += 0.1*vec3(1.0,0.4,0.2)*pow( sun, 3.0 );
    return vec4( col, 1.0 );
void mainImage( out vec4 fragColor, in vec2 fragCoord )
    vec2 p = (-iResolution.xy + 2.0*fragCoord.xy)/ iResolution.y;
    vec2 m = iMouse.xy/iResolution.xy;
    // camera
    vec3 ro = 4.0*normalize(vec3(sin(3.0*m.x), 0.4*m.y, cos(3.0*m.x)));
vec3 ta = vec3(0.0, -1.0, 0.0);
    mat3 ca = setCamera( ro, ta, 0.0 );
    // ray
    vec3 rd = ca * normalize( vec3(p.xy,1.5));
    fragColor = render( ro, rd );
void mainVR( out vec4 fragColor, in vec2 fragCoord, in vec3 fragRayOri, in vec3 fragRayDir )
    fragColor = render( fragRayOri, fragRayDir );
Material file: post_cloud.mat
<materials version="1.11">
<material name="post_cloud">
  <blend src="none" dest="none"/>
  <state name="states" type="switch" items="one,two">0</state>
  <shader pass="post" vertex="shaders/post/vertex_post_cloud.shader" fragment="shaders/post/fragment_post_cloud.shader"/>
  <texture name="color" type="procedural" pass="post" filter="bilinear"/>
</material>
</materials>
UNIGINE Script file: Tommy.cpp
#include <core/unigine.h>
Node box; // add a box node
int init() {
    PlayerSpectator player = new PlayerSpectator();
    player.setPosition(vec3(3.5,0.0,1.3));
    player.setDirection(vec3(-1.0,0.0,-0.3));
    engine.game.setPlayer(player);
    // search the node by the specified name
    int index = engine.editor.findNode("box");
    if(index != -1) {
        box = engine.editor.getNode(index);
    engine.render.setPostMaterials("post_cloud");
    engine.render.setBackgroundColor(vec4(0.5f,0.8f,1.0f,1.0f));
    engine.render.setShadowDistance(50.0f);
int shutdown() {
int update() {
    // check whether the node exists
    if(box != NULL) {
        // get the frame duration
        float ifps = engine.game.getIFps();
        // set the angle of rotation
        float angle = ifps * 90.0f;
        // get the current transformation of the node and calculate rotation
        mat4 transform = box.getTransform() * rotateZ(angle);
        // set new transformation to the node
        box.setTransform(transform);
My Modified Version in the engine: fragment_post_cloud.shader
#include <core/shaders/default/common/fragment_base.h>
* OpenGL
#ifdef OPENGL
uniform sampler2D s_texture_0;
uniform sampler2D s_texture_1;
uniform sampler2D s_texture_2;
uniform sampler2D s_texture_3;
uniform vec3      iResolution;           // viewport resolution (in pixels)
uniform float     iGlobalTime;           // shader playback time (in seconds)
uniform float     iChannelTime[4];       // channel playback time (in seconds)
uniform vec3      iChannelResolution[4]; // channel resolution (in pixels)
uniform vec4      iMouse;                // mouse pixel coords. xy: current (if MLB down), zw: click
uniform sampler2D iChannel0;          // input channel. XX = 2D/Cube
uniform vec4      iDate;                 // (year, month, day, time in seconds)
uniform float     iSampleRate;           // sound sample rate (i.e., 44100)
    vec3 p = floor(x);
    vec3 f = fract(x);
    vec2 rg = texture( s_texture_0, (uv+ 0.5)/256.0, -100.0 ).yx;
    float f;
    float f;
    float f;
    float f;
    // lighting
    col.xyz *= lin;
    col.a *= 0.4;
    col.rgb *= col.a;
    float t = 0.0;
    MARCH(30,map5);
    MARCH(30,map4);
    MARCH(30,map3);
    MARCH(30,map2);
    // background sky
    // clouds
    // sun glare
void main()
    vec2 p = (-iResolution.xy + 2.0*gl_FragCoord.xy)/ iResolution.y;
    // camera
    // ray
    s_frag_color = render( ro, rd );
#endif
My vertex shader file: vertex_post_cloud.shader
#include <core/shaders/default/common/vertex_base.h>
* OpenGL
#ifdef OPENGL
in float4 s_attribute_0;
in float4 s_attribute_1;
void main() {
gl_Position = getPosition(s_attribute_0);
#endif
Hi Cinetec!
Looks like you forgot to set all the input uniforms such as iResolution, iGlobalTime, etc.
But didn't I have already declare these uniform variables? or should I change or add something else?
* OpenGL
#ifdef OPENGL
    vec3 p = floor(x);
    vec3 f = fract(x);
    float f;
    float f;
    float f;
    float f;
    // lighting
    col.xyz *= lin;
    col.a *= 0.4;
    col.rgb *= col.a;
    float t = 0.0;
    MARCH(30,map5);
    MARCH(30,map4);
    MARCH(30,map3);
    MARCH(30,map2);
    // background sky
    // clouds
    // sun glare
void main()
    // camera
    // ray
#endif
Dear Cinetec,
Declaration of uniform variable isn't enough, you have to assign some value to it. We have a bunch of built-in uniforms which are filled by the engine (like s_viewport, for example) but all user defined uniforms must be filled by the app.
First, you need to declare that uniform as a material parameter in material xml. After that just use Material::setParameter (https://developer.unigine.com/en/docs/1.0/scripting/library/class.material#setParameter_variable_vec4_void) to assign values to that uniform, you can do so both in the script and in C++.
