joshua.cook Posted April 23, 2015 Posted April 23, 2015 I'm currently working on creating a plugin for the Unigine Editor. I've created a custom class with two constructors as so class MyClass { public: Tile(char* apName); Tile(const std::string& aName); }; in the class that inherits from Unigine::Plugin I have class UnigineToolPlugin : public Unigine::Plugin { int init() { Unigine::ExternClass<MyClass> *mc = Unigine::MakeExternClass<MyClass>(); mc->addConstructor<char*>(); Unigine::Interpreter::addExternClass("MyClass", mc); return 1; } }; In the script I have int init() { MyClass cm = new MyClass("TEST"); } The script fails to load and the output from the console window is Variable::getExternClassObject() : can't convert string to char * __ptr64 Editor::update() : editor update function return 0 Does anybody have a clue to what is going wrong or what I may have missed? Please note this worked when I created a static function that takes a char* static MyClass* makeClass(char* apName); and then passed that in as a constructor mc->addConstructor(&MakeClass);
unclebob Posted April 24, 2015 Posted April 24, 2015 Hi Joshua! Thanks for noticing that, I'll do my investigation and report back. By the way, could you please try to use const char * instead of char* and tell me if that'll work?
joshua.cook Posted April 27, 2015 Author Posted April 27, 2015 OK, I changed from Unigine::String to const char * and it worked. Not sure why this broke when I went from code compiled into our software to a DLL; I had been using std::string. NOTE : When I say I went from Unigine::String I mean that I changed all string type inputs to Unigine::String to get things working. Switching to const char*, instead of just char*, didn't affect the program.
unclebob Posted April 29, 2015 Posted April 29, 2015 Joshua, I did some research, here's correct version of the code: #include <UnigineEngine.h> #include <UnigineInterface.h> #include <string> /* */ using namespace Unigine; /* */ class MyClass { public: MyClass(const char *name) { Log::message("MyClass::MyClass(const char *): called with \"%s\"\n",name); } MyClass(const std::string &name) { Log::message("MyClass::MyClass(const std::string &): called with \"%s\"\n",name); } }; /* */ int main(int argc,char **argv) { // export extern class ExternClass<MyClass> *my_object = MakeExternClass<MyClass>(); my_object->addConstructor<const char*>(); Interpreter::addExternClass("MyClass",my_object); // init engine EnginePtr engine(UNIGINE_VERSION,argc,argv); // enter main loop engine->main(); return 0; } As I said, the reason was that there's no implicit cast from char * to Unigine::Variable, the only one that exists is from const char * to Unigine::Variable. I think we didn't implement implicit cast to char * because of safety, so please use const char * instead.
joshua.cook Posted April 29, 2015 Author Posted April 29, 2015 Sounds reasonable to me. Thanks for the help.
