[SOLVED] Random selection of particle SubUV's
I have an image consisting 4 images using SubUV's (2x2 grid of images).  I can easily apply this and have it animate across the frames over time using the animation transform parameter, but how would I set a particle to randomly select one of the four images in the grid (with no animation)?
Hello, Ken!
You can uncheck "animation" in the material and check "Texture Atlas" in Nodes->Params. It'll threat your texture as 4x4 grid of images and will randomly select the frame. No 2x2 grid support unfortunately (you can extend your grid to 4x4 probably).
