ataylor Posted June 2, 2015 Posted June 2, 2015 I would like to incorporate a 3rd-party Windows control (deriving from CWnd) into my existing Unigine-driven Windows application. Is there a recommended way to do this? As an experiment, I tried simply adding the control to the Unigine window from application C++ using Windows CreateWindowEx API. The control was present (evidenced by mouse cursor changing when hovering where control should be) but invisible as Unigine UI was being drawn over it. Next, I tried creating new C++ class deriving from WidgetExternBase. In widget constructor, I again use CreateWindowEx to add control to Unigine window. In render function I call Invalidate() on control, forcing it to be redrawn. This helps make control visible on screen, but still is competing with Unigine -- Unigine and Windows are both drawing simultaneously to the area on screen, resulting in flickering. Eventually, I would also need to query widget position Windows control correctly: correct position, size, any applied clipping, etc. Continuing with the above approach seems like a lot of work and probably very error-prone. Is there a simpler way?
unclebob Posted June 5, 2015 Posted June 5, 2015 Hello, Adam. I'm not sure what you're trying to achieve and assume you want to draw native UI inside Unigine viewport. For that cases I believe you have to inherit from our App class and write your implementation which will manage window order & focus so you'll be able to see custom controls. Another way is to use Unigine as a viewport and surround it with native UI. That approach also require custom App class. Have a look at this integration sample: https://developer.unigine.com/en/docs/1.0/cpp_api/usage/unigine_app/AppQt
