[SOLVED] Console spamming errors 2nd time opening two nested dialogs using UI files
Main window has button that spawns permanent-focus DialogOne. DialogOne has button that spawns permanent-focus DialogTwo. DialogOne is always populated using UI file. DialogTwo is populated either using UI file or programmatically in UnigineScript, depending on if SHOW_BAD_BEHAVIOR is defined. If defined, it uses UI file. If not, it uses programmatic population. When DialogTwo uses UI file, opening it for the second time causes endless console errors.
Reproduction steps:
Load the attached world
Click button to open DialogOne
Click button in DialogOne to open DialogTwo
Close DialogTwo
Close DialogOne
Endless console spam!?
Optionally, edit test.cpp, comment out #define SHOW_BAD_BEHAVIOR, reload world, problem is not reproducible without 2nd dialog using UI file.
What is going on here?
test.zip
Hi Adam,
This is also not a bug, you forgot to delete widget when you no longer need it (if you call new, don't forget to call delete!). Just add
delete d;
at the end of OpenDialogOne() and OpenDialogTwo() functions and you will not get any script crashes.
I see. I had a misunderstanding about how UnigineScript does memory management. I will re-read docs.
I am still confused and curious as to why this problem happens only when using a UserInterface.
