paul.chaney Posted July 15, 2015 Posted July 15, 2015 Hi, I'm trying to create a file naming convention for objects in our library that allows us to easily import node references into new sceneries and clone the objects around. Here is an example: hzn_people_emergency_fire_fighter_male1_p1_0 hzn = our tag people = group emergency_fire_fighter = object type male1 = sex/iteration (e.g. if we created more male firefighters they would be called male2, male3 etc... p1 = pose (so we can have multiple poses for each static character) _0 = copy reference number for Unigine. I.e. if we add multiple clones, they would be called: hzn_people_emergency_fire_fighter_male1_p1_0 hzn_people_emergency_fire_fighter_male1_p1_1 hzn_people_emergency_fire_fighter_male1_p1_2 etc... I would like to keep the filenames specific to the actual object however: e.g. hzn_people_emergency_fire_fighter_male1_p1.node I had thought this was controlled by the name parameter in the line <node type="ObjectMeshStatic" id="487315556" name="hzn_people_emergency_fire_fighter_male1_p1_0"> of the node file. However I'm finding that there are some inconsistencies - it seems to work for some objects and not for others and it's different in different versions of Unigine. I'm sure there's some logic to it, but can't seem to find the best way to make it work. Please could you provide some advice? Thanks & kind regards,Paul
silent Posted July 15, 2015 Posted July 15, 2015 Hi Paul, I'm not sure, but maybe a set of properties assigned to each node can solve this issue? You can check if node have some property assigned and based on this information change your simulation logic. We used similar approch heavily in GameFramework. Another solution maybe a setData() / getData() methods for Nodes that will allow you to store any xml data inside *.node file. Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
