werner.poetzelberger Posted July 23, 2015 Posted July 23, 2015 Is there a way to combine PBR materials with SSS? thx. werner
werner.poetzelberger Posted July 23, 2015 Author Posted July 23, 2015 The only thing is, how do I mask the materials? If I use SSR I cant use a auxiliary color. The SSS is applied to the PBR material and only doe not show if a different auxiliary color is chosen. (therefore I have to switch auxil. to default, which disables SSR). Is this correct?
sebastianbah Posted August 7, 2015 Posted August 7, 2015 Hi Werner, I'm afraid for the current SDK it is correct, because SSR works with an auxiliary buffer. This problem has been already fixed and in next SDK release SSS + SSR will be available.
