Unlit material (texture color)
Hi all,
I've been playing around with diffuse materials and have decided I'd simply like my object material to be a simple "unlit" texture without being affected by lighting.
Is there an easy "built in" way to do this?  Currently I'm having to use a diffuse material and turning off all the light settings for it, which gives a very dark texture - not what we're after.
Any help would be appreciated.
Cheers,
Simon
Maybe you could inherit new material from standard mesh base material and just replace fragment shader with stripped-down version only unlit color values ?
you can just set ambient to lightmap - and use default white texture as lightmap
