Shader Compilation Error
hi, in all cases if occurs syntax error in shader - application freezes, and OS, how fix it?
I also have this issue here on my working computer under DX11, after a couple of frames. I could imagine it has also something to do with the graphics driver.
Anyways, the way I'm dealing with it is: I load the application and terminate it immediately afterwards, with the following code in my update() function:
	if(engine.game.getFrame() > 2)
		engine.console.run("quit");
Then I check the error log and start again, until all shader compiler errors are ironed out.
cheers
 Helmut
i done like this with Shader class, but this class compiler need to make all includes with absolute path
