shaders refactoring
Hi, i downloaded Unigine 2.0 and run it.
i have small lib for shaders (lib.h) with my classes and double - functions
class cl1 {
  float v1;
  double v2;
double dblFunc1(double v1) {
  return v1* 2.0;
shader compiler:
Vertex shader failed to compile with the following errors:
ERROR: 0:473: error(#133) Reserved word: double
ERROR: 0:472: error(#133) Reserved word: class
ERROR: 0:473: error(#132) Syntax error: "double" parse error
how write new shaders? i need classes and double
Hi Sergey!
If you want to use the double precision in shaders on OpenGL, you need a graphics card with support for the GL_ARB_gpu_shader_fp64 extension set for the specific OpenGL shader:
##extension GL_ARB_gpu_shader_fp64 : enable
There is no support for the class concept in shaders, the closest analog is struct.
