unknown token "AutodeskImport"
I wanna use the AutodeskImport Class to import some FBX models in my Unigine scripts( Unigine 2.0 stable version ). However, the interpreter do not recognize "AutodeskImport", and there is no Autodesk dynamic link library in the sdk's lib folder either.
So How can I use the AutodeskImport Class in my Unigine Scripts? Could you give us some instructions?
Best Wishes
Thanks.
Hi TingWu,
Autodesk plugin functionality is moved directly into Unigine Editor. Right now we don't ship Autodesk as external dynamic library (but maybe it will be changed in future).
Right no you can use AutodeskImport class if you will launch your world with a help of Unigine Editor. Internally it is still uses AutodeskImport class. You also can hide Editor UI with a help of editor_quit command.
  • 2 years later...
I'm loading my script using "-editor_script" but still getting the same error message.
(Edit: this is on a locally-built but unmodified 2.3.1)
Edited by Greg.Mildenhall
Any ideas about what else could cause this error? Do I need to #include something? I didn't with ColladaImporter. Is there an example script somewhere of how to use AutodeskImport?
Hi Greg,
Are you launching editor_*.exe or your compiled binary (like main_*.exe)? I'm afraid, you will have to launch standalone Editor application in order to get AutodeskImport functionality available from script.
