grass_impostor_base orientation
hi, i am using impostors for trees on nonXY plane (spherical surface).
trees renders incorrect, it rotating and do not matching with tree axis.
how set basis for impostor?
Hi Sergey,
Thank you for the test scene. If I understand your test scene correctly:  you are placing impostors + clutter on some plane and you always get vertical impostors alignment? You can try to modify impostors shaders to get the correct orientation in your test case. Right now we don't have plans to implement such functionality for impostor material.
We also have sample with correctly aligned impostors with Orientation and Intersection flag enabled (please, check the data/samples/materials/impostor_04). I've replaced ObjectTerrain with plane mesh in that test scene and everything is worked as expected (positions can be slightly different while rotating, but it is not the correct use-case anyway).
