renato.semadeni Posted December 2, 2015 Posted December 2, 2015 Hi chaps I'm looking for a possibility to find out if a node is a field. In the API there are a lot of this calls but not for FieldAnimations. Do you expose this in a future release, or do you have a workaround for it. I'm thinking about checking to type against its name... Kind regards, Renato
shodan Posted December 2, 2015 Posted December 2, 2015 Hi, We'll add this, thanks for pointing us to a missing method! In the meantime, you can either check Node::getTypeName() indeed, or you can check Node::getType() type index. This should work both in C++ and script APIs. (Except that I don't think we expose the type constants via C++ API, perhaps we should do that too. We do expose them as NODE_xxx constants via script, though.) In the latter case, i.e. with getType(), beware that the specific values may change in the future versions. So don't hardcode checks like if (mynode->getType()==234), they will break eventually.
renato.semadeni Posted December 3, 2015 Author Posted December 3, 2015 Hi Andrew Thanks a lot for the input. We have currently a workaround with getTypeName(). It would be nice to get those methods and as well the type constants in the C++ API! =) kind regards, Renato
