p.vaz Posted December 8, 2015 Posted December 8, 2015 Hi, Since I've archived a script folder into a ung archive, I get problem accessing directories in this same archive : Extract of a script that works unarchived and fails archived : string dirName = engine.getDataPath() + "my_directory"; Dir dir = new Dir(); dir.open(dirName); // returns 0 when the script is archived ! Could you please tell me why it doesn't work ? and if is there another way to do that inside a ung archive ? Thx, Best regards, Philippe
maxi Posted December 9, 2015 Posted December 9, 2015 Hi Philippe, There are no directories in ung archive, only files with paths. If you need to open file, just use File::open(engine.getDataPath() + "my_directory/my_file"). If you need to get list of files, located in the current directory that is in archive, you need to do something like this: string dir_name = "packagefolder/otherfolder/"; // name of the directory in the package string package_name = "package"; // name of the package file // find package num int package_num = -1; forloop(int i = 0; engine.filesystem.getNumPackages()) { if(package_name != engine.filesystem.getPackageName()) continue; package_num = i; break; } if(package_num == -1) { // package not found return; } // get package files string files[0]; engine.filesystem.getPackageFileNames(package_num,files); // iterate over package files and take needed ones string needed_files[0]; foreach(string file; files) { if(strncmp(dir_name,file,strlen(dir_name))) continue; needed_files.append(file); } Also note, that if archive isn't loaded, you need to load it first by engine.filesystem.loadPackage.
p.vaz Posted December 9, 2015 Author Posted December 9, 2015 Thanks a lot for your answer, I've tried like in your example and it worked. For information, the archive wasn't loaded, I needed to load it first with engine.filesystem.loadPackage like you said.
