werner.poetzelberger Posted March 3, 2016 Posted March 3, 2016 Hi, I have a scene with a lot of textured objects, I want to export to unigine. All the objects have materials and textures applied in Maya. How do I get them exported and a material libriary as well with the assigned texures (at least DT). In a 1.x Version of Unigine we wrote our own Material creator), based on textfiles from sceneobjects in 3ds max. Is there a convinient way to export/import all that? Fbx and material libs does not seem to function right out of the box. Especially not for Maya. As we have a lot of objects, it would take quite some time to create materials and assign them one by one... thx. Werner
silent Posted March 3, 2016 Posted March 3, 2016 Hi Werner, We've fixed couple of importing issue in 2.2 beta - have you checked import in 2.2 beta SDK? If you still have troubles with importing the FBX files with the textures - can you please send us couple of such files for investigation? I will ask our artists with Maya to share information about FBX export / import, but I don't think that it differs much from 3Ds Max export, for example. Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
werner.poetzelberger Posted March 3, 2016 Author Posted March 3, 2016 Oh wow. very useful! Doing import right now with 2.2. Thank you!
werner.poetzelberger Posted March 3, 2016 Author Posted March 3, 2016 What is the texture declaration? Albedo and Normal works with Diffuse and Bumpmap slot in Maya. Are there any other maps beeing exported?
werner.poetzelberger Posted March 3, 2016 Author Posted March 3, 2016 In your 3dsmax link, the images wont load, so I cant see the details.
cryunreal Posted March 3, 2016 Posted March 3, 2016 Hi! What shader do you use in maya? Standart Blinn? And what do you mean by asking about texture declaration?
werner.poetzelberger Posted March 4, 2016 Author Posted March 4, 2016 Hello, we use standard Blinn mostly. Albedos and Normal maps do work. I am wondering if there is a way to assign the other texture slots for an Albedo material as well.
maxi Posted March 10, 2016 Posted March 10, 2016 Hi Werner, In specular workflow diffuse and specular slots are used, in metelness: diffuse slots assigns to albedo and both normalmap and bumpmap slots assigns to normal slot. Additional 3dsMax specific slots are supported: texmap_diffuse and texmap_bump. Any other slots currently are not supported.
m.berthaud Posted January 24, 2017 Posted January 24, 2017 Hi, We are currently work with 3D model edit with Maya and using 'Stingray PBS'. But none texture are import in Unigine. Do you know if it will be add in Unigine to work with PBR? Thanks.
silent Posted January 24, 2017 Posted January 24, 2017 m.berthaud, Could you please provide this FBX with all the textures?Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
m.berthaud Posted January 24, 2017 Posted January 24, 2017 Hi silent, I attach the FBX and all textures. I hope it will help you to provide an answer about it. Thanks! Ball_Example.rar
