Physics are not working if camera not looking
Hi, I have developed a game over game framework. I am using your Car, Level, Driver examples.
My car is getting commands from UDP ( wheel, gas, brake etc.)
Anyway, If my camera is not looking at my car physics are not working. It gets ignition, gas but it is not moving unless I turn camera to car.
Is there anything to fix it? It makes no sense. I should not always look at my car.
Before you ask, my code is too huge and complicated to send. But I don't think there is something about my code. There must be a setting maybe rendering setting.
Thanks.
Physics simulation stops when:
1. player is not set,
2. distance to the player is greater than engine.world.getDistance() or engine.physics.getDistance().
So I think tuning both world and physics simulation distances should help.
Is there any limit for distance. If it is too big, fps down etc. ?
Both physics and world distance is 1 000 000 000 units.
What is units? Meters? Centimeters?
My distance where physics is not working is at most 300 meters.
Also I think my problem is not distance. I multiply distance by 10000 and nothing changed.
If I do not move camera but only look the car that should run physics, physics starts.
If I look to ground physics not working but If I look at the car in same distance physics starts to work.
Hi Yiğit,
Unfortunately, we ran out of ideas :( Could you please provide a small (or not) sample with that issue so we can tell you what is causing it?
  • 1 month later...
I forgot to say it is game framework.
I can't provide sample, sorry.
But if you need any particular part of code I can provide.
