fbx export does not work for node reference
First, I would like to thank for adding this option so fast. Anyway it does not work properly. I have object made from many node references (we are using only node references). Each node reference contains single mesh with several surfaces. Fbx file is created, structure of objects seems to be OK, but there are no polygons. I tried to export single node reference, it does not work too. It works only when I export objectmeshstatic.
Hello Jirka
if i understand correctly, you want:
1. export from node reference, that contains objectmesh, into one fbx-file.
2. export from several node references into one fbx-file.
if i'm wrong, correct me, please
that's all or maybe something else?
Yes, thats what we need. Export to .mesh alredy works in this way.
Hi Jirka,
We've prepared small editor update for you. Please, check the PM.
Any feedback is highly appreciated :)
