Uncompressed texture assignments for material
I have the following situation:
We use the uncompressed function for textures, which comes in handy.
Our material libs have sometimes a lot of materials.
If I have a lot of materials, I assign the textures using a text/editor.
So e.g. .... /uncompressed/mytexture_alb.png
The issue is, that those .mat files do not convert into .dds file format automatically when I open the scene with the edited material libs.
So I need to click every material and texture, to beeing converted, which is very painful if you have 10s or 100s of materials.
Can this be optimized/automated??
Thx.
Werner
Hi Werner,
If I understand you correctly, you are copy-pasting the texture path into the texture slot editline widget? Or you directly editing the *.mat files?
I'm afraid, uncompressed folder handling logic is working only if you will manually choose texture from the UnigineEditor.
Ok, thank you!
