image RGBA16F issue
hi:
   When you use grabber to capture a cubemap or 2d image in hdr mode, you get a rgba16f. Now i want to read that image value use image.getCube() / image.get2D();
   You can't read that image as it's not supported. Hope this could be fixed as rgba16f is quit common now
thanks
Hi Cinetec.
getCube() and get2D() methods returning Unigine::Pixel as union output. You can read pixel as float or as int using f or i postfixes.
For example:
Unigine::Pixel pixel = getCube(...)
float r_channel = pixel.f.r;
Have you tried this approach?
		case FORMAT_RGBA16F: {
			unsigned short *d = (unsigned short*)&data[id * 8];
			p.i.r = *(d + 0);
			p.i.g = *(d + 1);
			p.i.b = *(d + 2);
			p.i.a = *(d + 3);
			return;
should it be p.f.r=*(d+0);? since it's float
Hi Cinetec,
There is no error in case of RGBA16F format.
Engine store pixel values inside i because there is no special half type in C++ (actually, inside each pixel a bit representation of half type is stored). That's why that part of code was written.
Later you can access pixel values via f union for more convenience.
