Creating C# application in Linux
I'm trying to get started with this guide to create a C# application: https://developer.unigine.com/en/docs/2.2.1/code/csharp/application
I have installed Mono the way that is recommended in the guide, and it works.
But when I try to create a new project in UNIGINE SDK Browser, I can only choose between the APIs C++ (GNU Make), C++ (QMake) and UnigineScript only.
What do I miss or do wrong?
Hi Christian,
We are deeply sorry for misleading you, but C# API is not supported anymore on Linux and Mac OS X platforms. We plan to return in little bit later (can't give you any ETA right now, sorry).
Documentation will be updated ASAP.
Thanks for the response.
If I make a game in Windows with C#, is it possible to play the game in Linux?
Hi Christian
If few words - no. Your game written in C# language will not work currently on Linux.
Unigine C# API contains two parts: UnigineWrapper (platform-depended) and UnigineSharp (should be used Windows version) libraries. On Windows they have *.dll extensions. On Linux UnigineWrapper should be rebuild with native Linux compiler (for example, GCC) and should have *.so extension.
Theoretically you can rebuild UnigineWrapper on Linux manually, but you should have at least access to the engine source files (which are not included into Evaluation kit).
