Call methods from base class
I have two classes:
class BaseObject
		Node node;
		string name;
		void init(Node node, string name = "")
			this.node = node;
			this.name = name;
			log.message("BaseObject::init()\n");
		string getName()
			return name;
		Node getNode()
			return node;
		void setName(string value)
			name = value;
		void setNode(Node value)
			node = value;
		void shutdown()
		void update()
class SwitchObject : BaseObject
		void init(Node node)
			BaseObject::init(node);
			log.message("SwitchObject::init()\n");
		void shutdown()
			BaseObject::shutdown();
		void update()
			BaseObject::update();
If I do next:
SwitchObject object = new SwitchObject();
object.init(someNode);
all good, I see trace:
BaseObject::init()
If I do next:
BaseObject object = new SwitchObject();
I see trace:
BaseObject::init()
It's not correct
you're requesting a virtual function feature in script engine.
I think that's not posible nor easy task for a script engine.
I have two classes:
All functions are treated as virtual.
Try use same signatures for init function.
init(Node node, string name = "") and init(Node node) is different functions from script point of view.
I see, thanks
You are developing very powerful system: beautiful render, excellent cross-platform engine and internal script, that allow abstract from specific platform - IMHO, you should little by little upgrade you script OOP features - it will be amazing for developing :)
well, my mistake :) , I didn't notice you are using different parameters, so these different parameter make these two function as normal member function. So what you get is correct result.
Actually I use OOP everyday :)
