ENGINE_ANALYZER_SECTION Macro
Proposal
For tracking down code section hot-spots within a function some special EngineAnalyser macro e.g. ENGINE_ANALYZER_SECTION might be helpful. This would allow section timing outputs to console via "engine_analyser" command.
quick-and-dirty implementation in EngineAnalyser.h
#ifdef NDEBUG
   #define ENGINE_ANALYZER_SECTION(TYPE,FUNCTION,ARGS,SECTION,SECTIONNAME) (static_cast<void>(0))
#else
   #define ENGINE_ANALYZER_SECTION(TYPE,FUNCTION,ARGS,SECTION,SECTIONNAME) EngineAnalyzerLock engine_analyzer_lock(#FUNCTION # ARGS " section " # SECTIONNAME, (const unsigned char*)((SECTION) + 256 + (size_t) GetFunctionPointer(TYPE &FUNCTION)));
#endif
Maybe there is a much more elegant solution for avoiding current manual section number and redundant function signature specification requirement...go for it, Alexander
Usage Example
Searching performance hot-spots for world update
void World::update_multiple(float ifps)
   ENGINE_ANALYZER(,World::update_multiple,());
   // update nodes
       ENGINE_ANALYZER_SECTION(,World::update_multiple,(),0,update); // ENGINE_ANALYZER_SECTION(update) would be nicer
       int id = engine.threads->runJobs(update_jobs + 1,sizeof(WorldUpdateJob),num_threads - 1);
       update_jobs[0].process();
       engine.threads->waitJobs(id);
   // flush nodes
       ENGINE_ANALYZER_SECTION(,World::update_multiple,(),1,flush);
       // flush update nodes
       for(int i = 0; i < num_threads; i++) {
           update_jobs[i].flush();
This would reveal for the following example that most of total function time is spend for node flushing (BTW caused by spatial update of large vegetation node counts generated by WorldClutter)
