combobox multiselect issue
it seems the lights combobox callback have a bug. it might affect all objects which have a combobox ui
1:create a projection light
2:copy another one and change it's combobox property like shape to rectangle.
3:now select both lights (you need first the last one you created and then select the first one, other way won't reproduce)
4:check the property, the second one shape changed to the same as first one.
it doesn't matter if you copy or create a new projection light. so far just combobox properties are affected.
please provide a fix asap
it's seems related to the changed callback. temporary  if i use Clicked event it's ok.
I guess it's because when select the otherway the ui will change when you do multiselection.
