demostenes Posted January 1, 2017 Posted January 1, 2017 When I move some terrain layer material up or down, its mask stays on place. Is this desired behaviour? I would expect layer will "carry" its mask on the new place, so I can reorganize materials during whole project and have better control what is going first.
sebastianbah Posted January 9, 2017 Posted January 9, 2017 Hi, Such behavior helps you not to modify all mask arrays in every move of the material and I'm afraid, it's a correct behavior. To get the right order for the masks after moving the layers, please, reimport masks on Import tab. Displacement of the layer do not change the accordance of the mask textures on Import tab. Also, if you modify masks using terrain editor, export the modified version of the mask for reimport from Export tab.Thanks!
demostenes Posted January 9, 2017 Author Posted January 9, 2017 To get the right order for the masks after moving the layers, please, reimport masks on Import tab. Displacement of the layer do not change the accordance of the mask textures on Import tab. Also, if you modify masks using terrain editor, export the modified version of the mask for reimport from Export tab. Ok, not big problem. But currently it is not possible due to crash bug: https://developer.unigine.com/forum/topic/4100-terrain-mask-export-crash/
