Calling C# scripts from C++
Hi All,
Just to confirm - there is no way to call c# scripts from a C++ application correct?
You can call UnigineScript from C++ and you can also access UnigineScript from a C# app.  But it's currently not possible to mix C# and C++ in the same application?
Is this correct or is there a solution to this?
Any help would be appreciated.
Cheers,
Simon
Hi Simon,
Unigine is designed to be embedded into the C++ or C# application and has no capability of C# scripting as it is in Unity.
This may change in future, but now the only scripting language available is UnigineScript.
Even without help from the engine, you can still mix C++ and C# in your application.
The method of calling unmanaged functions from C# is quite well known and is called P/Invoke.
But calling the C# code from the C++ is a way trickier.
Some cases can be solved using a technique called Reverse P/Invoke and we use it ourselves in our C# API implementation.
Depending on your task it may be more practical to write intermediary C++/CLI library but this approach is only available on Windows.
I can also imagine a very twisted way of using UnigineScript as an intermediary, but I hope you'll ignore this idea :)
