Hide Unigine splash
How can we hide Unigine splash (powered by Unigine 2).
Priyank,
You need to change World (and maybe in some cases System) splash screen. Please, refer to the Splash class methods documentation here: https://developer.unigine.com/en/docs/2.4/api/library/engine/class.splash
The best choice is to put this code in SystemLogic (in case of C++/C# application) or by modifying system script (unigine.cpp - UnigineScript) in init() after systemInit().
Note, that even if you will disable splash (pass NULL to setWorld() / setSystem) it will render black screen with LOADING text, so it's better to use some blank textures instead.
Please correct me if I am wrong.
  • By SystemLogic you mean AppSystemLogic::init(), this way we have to change the Unigine source every time we upgrade to new version
  • After systemInit() you mean before Unigine::Engine::init
That's the sources of your project, so it will be no need to change it every upgrade.
In unigine.cpp inside your <Project>/data/<project_name>/unigine.cpp inside init() after systemInit().
The issue was basically USE_CUSTOM_SPLASH define is not created if we build the engine using "build.py", although in SConstruct file splash is set to 1
BoolVariable('splash','Custom splash',1),
and looks like passing --features=splash in as extra options may enable that.
Is this expected? I thought values given in SConstruct will override the parameter value.
Hi Priyank,
All flags are enabled by default if you will rebuild engine via Visual Studio. By default in build.py this feature is disabled and invocation of build.py will overwrite Sconstruct flag (1 -> 0).
You have to explicitly specify features that you need in build. Please, keep in mind that you don't have to use '=' sign to specify features that you want (it will not work with multiple features):
build.py --features splash microprofile //correct
build.py --features=splash microprofile //will only enable splash feature
More likely that behavior will be changed in future.
