f.reichl Posted April 4, 2017 Posted April 4, 2017 Hi, is it possible to enable the automatic reloading of meshes (when updated in the filesystem) in play mode, not only in the editor? In addition, is it possible to change the frequency with which updates on meshes are propagated to the Engine? Regards, Florian
maxi Posted April 20, 2017 Posted April 20, 2017 Hi Florian, Engine automatically updating some changed resources when editor script is loaded (see checks for engine.editor->isEnabled in sources). For using this in your app you just need to load an empty editor script: Unigine::Editor::get()->load("empty_editor_script.cpp"); Empty editor script must implement 3 functions: int init() { return 1; } int update() { return 1; } int shutdown() { return 1; } As for the frequency, there is no api for this, but if you can recompile engine, check RenderManager.cpp : RENDER_MANAGER_RESOURCE_CHECK define and WorldManager file.
