Object Rendered by Visualizer Flicker when the TAA option is enabled
If TAA in render options is enabled, the solid sphere rendered by Visualizer::renderSolidObject will flicker violently.
The renderSolidObject is called every time when the world updates or renders.
What can we do to solve this problem?
like this:
int CLBUNAppWorldLogic::init()
Unigine::Console::get()->setInt("render_antialiasing", 2);
int CLBUNAppWorldLogic::render()
Unigine::Visualizer::get()->renderSolidObject(pCurrentObject, Unigine::Math::vec4(0, 1, 0, 1));
Use the default material ball in default project.
I mean, use the default material ball shown in the picture below,  you would reproduce the problem.
liu.yan
Thanks, I've successfully reproduce this issue. Flickering is happens because real geometry is interfering with visualizer.
Maybe disabling rendering of the object will help in your case?
For example:
mesh_0 = ObjectMeshStatic::create("material_ball.mesh");
mesh_0->release();
mesh_0->setTransform(translate(Vec3(-2.0f, 0.0f, 0.0f)));
mesh_0->setMaterial("mesh_base", "*");
mesh_0->setViewportMask(0, 0);
Unigine::Visualizer::get()->setEnabled(1);
Unigine::Visualizer::get()->renderSolidObject(mesh_0->getObject(), Unigine::Math::vec4(0, 1, 0, 1));
In that case there will be no flickering and visualizer will display correctly.
The code fragment you had provided does solve the problem, thanks.
In TAA, we still can't render mesh and Visualizer solid together, will you solve that in future version?
liu.yan
It's hard to say right now. The issue is not critical and there is a simple workaround available. In case of any updates I will surely let you know.
  • 1 month later...
Morning, silent:
   Our next version development is about to start. Is it possible that this problem shall be solved in your recent release?
   I am reluctant to bother you on this unimportant problem, but our product manager had developed various applications based on this issue.
