Is there any C++ Api for rewriting image to viewPort(screen)?
Hi:
    I can't find any C++ api rewriting image to viewPort(screen), can you give some advise?  thanks.
If I understand you correctly, you want to customize the texture in the main viewport.
If it's so, please, check Render/GBufferRead and Render/GbufferWrite samples from C++ API chapter in SDK. Also Render/TextureRender sample may be helpful.
Also, you can find additional info in docs here.
Hi sebastianbah,
Sorry for the late reply.
You are right, I want to customize the texture in the main viewport. Thanks for your guidance.
I encountered oculus initial failed problem when test by the Render/GbufferWrite samples in unigine sdk 2.5, but oculus is normal in sdk 2.4.1.
What's the problem when using oculus in sdk 2.5, Oculus isn't Latest version?
Best regards!
Hi sebastianbah,
The invoke interface( int Viewport::addCallback) doesn't work when I test Render/GbufferWrite samples by HTC VIVE.
It workes normal when test in vs2015. Whether I need do any more work?
The normal image is post-2346-0-79301100-1498042989_thumb.png.
Best Regards!
Hi Zhong,
Please, don't hesitate to contact our Chinese support team directly via china-support@unigine.com.
This sample is not designed to be working with AppOculus / AppVive, you can check the sources. In order to modify Oculus / Vive texture you need to get that textures first. It's possible only with the sources of App* plugins that are not available in Evaluation kits.
Hi silent,
Thanks for your answer. I am not only modify the model texture but also modify the viewport texture by camera picture. I want to achieve the effect of Mixed Reality in oculus/htc. I will contact Chinese support team.
Best Regards!
