[SOLVED] GUI element not added in AppWorldLogic::init()
The below code adds a button to the screen when run in main()/winmain()
    GuiPtr gui = Unigine::Gui::get();
    WidgetButtonPtr widget_button = WidgetButton::create(gui, "click");
    widget_button->setCallback0(Gui::CLICKED, MakeCallback(Utils::testit));
    gui->addChild(widget_button->getWidget(), Gui::ALIGN_TOP);
When the same code is run from AppWorldLogic::init() the button does not appear, even though the routine is run.
Any idea where I'm going wrong?
Hi Angus,
As you may know Unigine::Ptr<> is somewhat similar to std::shared_ptr<> and maintains shared ownership of an object.
The lifetime of the WidgetButtonPtr in your code ends when the AppWorldLogic::init() returns and button is destroyed almost immediately after creation.
The right way to create a button with the lifetime of the scene is like this:
class AppWorldLogic : public WorldLogic
    virtual int init()
        GuiPtr gui = Gui::get();
    virtual int shutdown()
        widget_button.clear();
    WidgetButtonPtr widget_button;
  • silent changed the title to [SOLVED] GUI element not added in AppWorldLogic::init()
