reflection offset changes with blending mode
As you can see in the image
the reflection is different as compared to one in
alpha_test_reflection.jpg.
I need the same for alpha blend mode as well .at present its getting cropped
Hi Siddhesh,
Unfortunately, SSR is not working correctly with semi-transparent objects (alpha blend in your case) because it's rendered in forward path after the SSR is already calculated. This is technical limitation and could not be fixed.
In your case I think you can just use planar reflections of the floor to get similar results.
I am pllying planar reflection but still it shows the same reflection..?? what settings i need to do for planer reflection???
