siddhesh.jambhavadekar Posted September 9, 2017 Posted September 9, 2017 Pls see the attached video file. When i move away from any object specially which has emission enabled. it shows jitters also there are many jitters in the whole interior when camera moves away from them. how to fix this. in the video look out for the parts which i have highlighted with mouse pointer. My ssr settings are also attached as a image Thankyou Rec_09-09-17.mp4
silent Posted September 9, 2017 Posted September 9, 2017 Hi Siddhesh, The fastest way will be to send us your test scene so we can launch it on our side and check all the world settings. I'm afraid, it's not possible to find out the exact reason of this only by video. Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
siddhesh.jambhavadekar Posted September 9, 2017 Author Posted September 9, 2017 i was trying to upload the test scene yersterday but my file size is more then 70.15mb.
silent Posted September 9, 2017 Posted September 9, 2017 You can use any filehosting (like https://wetransfer.com/) or upload files directly to our FTP server: ftp://files.unigine.com user: upload password: iejeePheeH3che Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
siddhesh.jambhavadekar Posted September 11, 2017 Author Posted September 11, 2017 Ill send you through We transfer. On which email id should i send ..??
silent Posted September 11, 2017 Posted September 11, 2017 You can send it directly to my email: silent@unigine.com. Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
silent Posted September 11, 2017 Posted September 11, 2017 It seems that you've sent different scene. Which track needs to be loaded to see the effect? And where to look at? Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
siddhesh.jambhavadekar Posted September 11, 2017 Author Posted September 11, 2017 I have sended the scene which has low file size. anyways no need to load any track. just move in the editor and you can see the glowing objects which are in blue are causing jitters even in the editor also many objects have a outline which causes jitter
silent Posted September 12, 2017 Posted September 12, 2017 Hi Siddhesh, I've checked your scene and we can recommend you this TAA settings: Anti-aliasing become stronger, but you may notice blur in some areas (not a problem with high framerate). Also, you need to enable Color 16F (as I already told to Rohit) to avoid any color artifacts. You can improve visuals of emission objects by enabling full bloom resolution (instead of half). Unfortunately, for emission objects it's hard to do any anti-aliasing, so they rendering quality will not improve much. I don't know if that also helps in your initial test scene, if not, I'm afraid we would need to check the first test scene as well. For that kind of scene you can also use Box projection for environment probe to get some good reflections and GI simulation. You can check box projection samples in SDK Browser -> Samples -> Demos -> Samples 2.5 -> lightning. Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
