siddhesh.jambhavadekar Posted September 18, 2017 Posted September 18, 2017 Hello, My reflections and shadow problems are solved. pls see the attached image there is uneven lines on all the objects in the editor. Even without camera motion this problem is visible. I can send you the this test file. but by seeing the image can you suggest me some settings to solve this as of now .? Is this the problem of lighting ,sun or shadow ..?? or what ..?
silent Posted September 19, 2017 Posted September 19, 2017 Hi Siddhesh, It should not be hard to figure it out by yourself by changing different objects options. Using Rendering -> Debug menu you can also found which buffer is causing this (if there is an issue with it). Start with disabling post effects and then move to the lightning and rendering settings. Thanks! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
