Greg.Mildenhall Posted September 26, 2017 Posted September 26, 2017 On Unigine 2.3.1, I've edited data\samples\objects\terrain_00.cpp as attached. First using setLayerEnabled(i, false) to remove all the layers, then setAlbedoTextureName("") to remove the albedo texture, then creating an in-memory Image and applying it with setAlbedoTextureImage(). Unfortunately when I run the sample, the setAlbedoTextureImage() call does nothing. However, if I uncomment the second call to setAlbedoTextureName() which feeds it a nonsense value, the subsequent setAlbedoTextureImage() call suddenly works. So my question is whether (and why) setting the Name to "" should prevent setting the Image? (This might seem contrived, but in our real application we never load an on-disk texture so it acts as if the Name is "" from the outset. The workaround gives us the result we want, but obviously we're getting an error message from it so don't have faith that it's the right way to go.) terrain_00.cpp
silent Posted September 27, 2017 Posted September 27, 2017 Hi Greg, That's interesting behavior. I've successfully reproduced this in current 2.6 developer branch. Right now I can't say what exactly cause such behavior, but if I recieve more information from dev team I will surely let you know. Right now I think you should be safe to use this method to set the terrain texture (there will be error in console, as you already mentioned). Thanks for the bug report! How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
Priyank.Jain2 Posted October 25, 2017 Posted October 25, 2017 Faced similar issue and observed that there is a check before albedo texture is set int ObjectTerrainMaterial::setAlbedoTextureImage(const Image &image) const { if(albedo_texture_name.empty()) return 0; Image temp = image; return albedo_texture_ptr->setImage(temp); }
