terminate called after throwing an instance of 'char const*'
Hi and thank you for new Editor.
 Editor crashes when i choose "sun" or any other options in the left menu, such as "ground" or "material_ball". After much of pain i started a new project and reinstalled my Nvidia driver several times and i found this error massage in the console:
"The remote host closed the connection"
This happens under my Linux PC.
And by the way i see this error massage in console every time i start new editor:
"Adding of the runtimes failed. Runtime GUID = a73c9fd53c2ef69ffbc248f9101368fe6ec2721c"
Edited by vyacheslav.kuznetsov
Hi Vyacheslav,
Could you please send us the engine log (located in bin folder of your newly created project) and detailed step-by-step instructions how to reproduce this on our side?
Sure here is instructions:
1) Create project ( no addons installed )
2) Open the project
3) Select any entity inside World tab on the left side (sun, ground, material_ball)
4) Freeze
5) Console output (only if you run ./browser.run inside browser folder)
Reloading "assets.prop" 0 properties 0ms
---- Interpreter ----
Version: 2.90
Unigine~# config_readonly 0 && world_load "unigine_project" && render_antialiasing 1
Loading "core/unigine.cpp" 4ms
Loading "core/locale/unigine.locale" dictionary 0ms
Loading "guid://3c575dd40ffabcc07caf82d1ae1a0b391c40120d" 2ms
Loading "unigine_project.world" 44ms
But i didn't find any massage in the log file, related to this error.
As i see this error simply telling " you're catching the wrong type" ?
log.html
