[SOLVED] Editor2 crashed after editing NodeReference if you references nodes from it in update
I observed that Editor2 (SDK 2.6.1) crashes at the moment of applying edit of NodeReference by Apply button in editor in the case of using nodes from such NodeReference somewhere in UnigineScript in update function e.g.:
void update() {
nodeFromReference.getWorldPosition();
Here nodeFromReference is not nulled at this time so I can't prevent it.
As I see is a Editor issue.
Edited by Klimczak.Jan
Unfortunately, I can't reproduce your issue.
When I using nodes from NodeReference in UnigineScript, Editor 2 working properly.
Please give us more detailed step by step description of your problem.
15 hours ago, grmmvv said:
As I see the problem is not obvious. It's happens in more advanced scenarios.
That's why I send you a PM with a project where you can replicate the problem.
It is not happens every time as you do:
1. Open GalacticTanks world,
2. Select "czolg_1" reference node,
3. Click "Edit" button in Reference part of the Parameters node,
4. Then edit reference or just click "Apply" button to save reference node,
This sometimes crashes Editor2, if not you can then repeat 4 and 5 steps a few times until it will crash Editor2.
Here is other possibility to crash Editor2 like that:
5. Reload world.
This will crash Editor2 each time (after clicking Yes or No for question about saving changes).
Sometime you can just select an node in World list or in the scene instead a reloading world to crash Editor2.
Thank you for detailed description and test project.
I've successfully reproduce both cases and added it in our internal bug tracker.
There is problems in joints that you create in init method and use in update method.
There is two ways for a workaround:
Hi Jan,
The actual issue is that you are forget to call class_remove() on the following line:
JointWheel joint = new JointWheel(n0.getBody(), n1.getBody());
 this line should look more like this:
JointWheel joint = class_remove(new JointWheel(n0.getBody(), n1.getBody()));)
It is required to use class_remove() for created bodies, shapes or joints to release the script ownership.
Please, refer to this article about memory management: https://developer.unigine.com/en/docs/2.6.1/code/fundamentals/memory_management
  • silent changed the title to [SOLVED] Editor2 crashed after editing NodeReference if you references nodes from it in update
On 15.01.2018 at 12:13 PM, grmmvv said:
Thanks! It seems to work :)
Jan
3 hours ago, silent said:
Hi Jan,
Hi, You are right, that was my mistake. With class_remove() I don't see any crashes at the moment :)
