Nava.Sheridan Posted January 16, 2018 Posted January 16, 2018 Hi, I try to make some test using a 3rd party libraries. how can I set up the framework version for the samples to 4.5.2 instead of 4 ?
ded Posted January 17, 2018 Posted January 17, 2018 Hi! You can just open sample in Visual Studio ("Edit in IDE" in SDK Browser") and change target framework in project settings. This, however, has some pitfalls. Visual Studio will add app.config into the project, which upon rebuild rewrites file <sample>.exe.config. For correct sample running add these settings to app.config: <?xml version="1.0" encoding="utf-8"?> <configuration> <runtime> <assemblyBinding xmlns="urn:schemas-microsoft-com:asm.v1"> <dependentAssembly> <assemblyIdentity name="UnigineSharp_x64d" culture="neutral" publicKeyToken="f6ef6838e040fba0"/> <codeBase version="1.0.1.0" href="../../../../../../bin/UnigineSharp_x64d.dll"/> </dependentAssembly> <dependentAssembly> <assemblyIdentity name="UnigineSharp_x86d" culture="neutral" publicKeyToken="f6ef6838e040fba0"/> <codeBase version="1.0.1.0" href="../../../../../../bin/UnigineSharp_x86d.dll"/> </dependentAssembly> <dependentAssembly> <assemblyIdentity name="UnigineSharp_x64" culture="neutral" publicKeyToken="f6ef6838e040fba0"/> <codeBase version="1.0.1.0" href="../../../../../../bin/UnigineSharp_x64.dll"/> </dependentAssembly> <dependentAssembly> <assemblyIdentity name="UnigineSharp_x86" culture="neutral" publicKeyToken="f6ef6838e040fba0"/> <codeBase version="1.0.1.0" href="../../../../../../bin/UnigineSharp_x86.dll"/> </dependentAssembly> </assemblyBinding> </runtime> </configuration> Or you can just open .csproj file in text editor and modify this line: <TargetFrameworkVersion>v4.0</TargetFrameworkVersion> Also, we've noticed that C# sample projects have some wrong debug settings in the SDK. If sample won't run, replace text in "Command line arguments" for "All Configurations" and "All Platforms" with this: -data_path ../../../../../../data -data_path ../../data -data_path ./data We'll fix debug settings in future SDK releases.
