Klimczak.Jan Posted February 12, 2018 Posted February 12, 2018 (edited) Hi, Where I should create terrain data for generated terrain object via Editor2: in "assets" folder or just in "data" folder ? As I see all generated references points into data folder but when I create it in data folder then I don't have access to created terrain data via asset browser. Thanks, Jan Edited February 12, 2018 by Klimczak.Jan
morbid Posted February 13, 2018 Posted February 13, 2018 Hi, Currently landscape tool has limited integration with assets system. To be precise: When you're creating terrain via landscape tool usual practice is to store it in "data" folder. Please don't keep in assets, the amount of data could be really big. Some objects generated by landscape tool couldn't be added into assets. For instance decal material is stored in data folder. The simpliest workaround for this is creating custom material in editor. When you configuring roads or vegetation in landscape tool it shows you by default data folder. I guess it is easier to find the required node file in data but if you want you can select it from assets folder. We're aware of this issues and working towards improving landscape integration with assets. Is there anything else I can help you with? 1 How to submit a good bug report --- FTP server for test scenes and user uploads: ftp://files.unigine.com user: upload password: 6xYkd6vLYWjpW6SN
Klimczak.Jan Posted February 13, 2018 Author Posted February 13, 2018 Hi, Thank you, so I will wait for enchacement tool :) and report BUG for missing references for generated textures during creating TextureObject in Editor2. Thanks 1
